puttin it in a 70 baja ej22 or a carburatored 1800
which will
be most reliable simle motor to use with plenty of ggs but not too much so im breakin shit?
Ej 22 everday
With Andrew.
EJ22 all the way
i remember hooting around the streets of the gold coast in that thing with gordon and just being so impressed by how well a flogged old subi pulled with 4 ppl in and big offroad tyres
Come on Phil cant believe u even asked that question!!!!, EJ22!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The cost of an EJ conversion will be the same as an EA Conversion unless you have stuff already in place. The EA81 / EA82 are a fine engine and will
serve you well. In a baja it will crap all over a VW engine of the same size and be very reliable.
I would go EJ 22 any day as I find it easier to work on EFI than Carbies, but that is my prefference, my lawnmower still has a carbie.
At the end of the day either will be fine.
type 4 2 ltr, stuff the water cooled
you would get away with a type 4 for around 1500 i reackon, 500 motor, 550 conv kit, 350 exhaust maybe 100 extra crap maybe
i have a fuel tank that will bolt straight in
to suit injection
add 3 fuel lines and a vl commodore pump and it is fitted
very easy
ring me 0403252522
terry
Ej25 quad cam all the way !
get some low down grunt from the ej25
hmm what about a 71 panel van /ej25 seagull is it and easyish fit?
