yeah
baghall - May 8th, 2010 at 10:15 PM
Finally was able to give the baja a lift today. Have now got loads of positive camber. Hopefully it will settle a little once I drive it. Typical
though in doing the job I found some problems with cracks that need to be fixed and the mounting bolts for the body were loose, about 5mm movement.
Guess thats the price of doing it yourself. At least it's cheaper.
Smiley - May 8th, 2010 at 11:31 PM
Pictures?
Smiley
bajachris88 - May 9th, 2010 at 12:31 AM
I assume this is lift via torsion bar adjustment or body lift kit? none the less, can never get enough lift !
second pics! before and after shots for the way
Smiley - May 9th, 2010 at 08:55 PM
Originally
posted by bajachris88
You can on a swinger
Smiley
baghall - May 9th, 2010 at 10:09 PM
Here are the photos. First photo doesn't really show the difference but my sons were shocked when they saw it. Can actually feel the suspension
working now> I think they were bottoming out a lot before.
Smiley - May 9th, 2010 at 10:39 PM
Is that a tiny coffin lid on the back in the first picture?
Smiley
bajachris88 - May 9th, 2010 at 11:06 PM
Originally
posted by smileyman3000
Smiley
hahahaha, i wouldn't know
That sits very nicely too btw. good work
The as barwork is a good
improvement as well. I like that very mcuhly
matberry - May 10th, 2010 at 08:57 AM
Carefull no-one dies, with a swinger that high they don't handle too well !!!!!
baghall - May 10th, 2010 at 09:23 AM
Originally
Smiley
Err, that was put on by previous owner to get past rego. Didn't like the look of it. It hung below engine and mounted off prewarmers on exhausts and
tinware. Not very strong.
Thanks for the comments.
baghall - May 10th, 2010 at 09:25 AM
Originally
posted by matberry
Yeh major handling change from negative camber. Just gotta drive slower around corners and over speedbumps. Might lower a bit some time later, just
gonna see how it goes first.
