as it says boys fill me in
pictures would be a big help here or sites detailing procedure
ron
this is only 2" but have a look,
http://www.btinternet.com/~aircooled/wolfsburgeast/home.html
none, if you don't run shocks.
If yr fitting the beam to a pre 67 car then you will have to reduce the width of the shock towers or do some body work to the inner guards to make it
fit reducing the shock towers will result in less body work.
Make sure you dont reduce the width or the fuel tak opening or the tank wont fit in.
I fitted a 1 in narrower beam the other day to my 65 and had to knock the inner guards in slightly It has stock shock towers
Any other info?
I'm also interested in this, but on a '68.
-Staggers.
On a 68 on or Ball joint front end you have a lot more clearance as the shock towers are angled out wards so you will only have the very lower
section of the inner guard to grind away or massage with a large hammer
what else do u need to know ??
The beam on my 68 ball joint is narrowed 3.5 inches. Slightly massaged inner guard to fit it. Put some 4.5" Fuchs on it. I think it looks OK.
cal 68 show us some oics![]()
I had my ball joint beam narrowed 80mm (3.14 inches) and just had to "massage" the inner guard area with BFH (big f'ken hammer) before paint went on. Beam now fits no probs. King and link pin beam will be different unless you run no shock towers, or custom towers. You can generally narrow 2 inches and plate the inner side of the shock tower with flat steel and get away with it...otherwise you have to modify the inner guards as well.
Here goes.
Does anyone know whether a narrowed and shockless beam is legal in NSW, thinking of a 7 inch narrowed beam, if it's not legal i'll just have an OG one ready for rego each year........
surely it wouldn't be legal to run no shocks, in any state....
depends on your deffinition of shocks
as the leaves in the bar work as a
shock absorber. but no i dont think its legal anywhere.
