Hi guys
I've bought new koni reds. BJ/IRS Pretty keen not to stuff them up. I'll have another read of the instructions but, if your able to simplify that
would be great. I'll probably leave them at full soft for now.
Also I have sway away adjusters in the front and it's low ish will I need to worry about bottoming out and damaging the shock. I have seen people use
seatbelt looking stops...
Being low, I'd start at 1/2 way. The seat belt straps are for limiting droop which becomes irrelevant on a low car as the springs will loose tension often before the suspension stop.
