shagged lower balljoints
cnfabo - April 9th, 2014 at 09:14 AM
Hi guys,I have noticed my lower ball joints are floppy jaloopy and have been in the car for maybe two years.its got me stumped why they are stuffed
already..I thought they should have lasted a lot longer then this...do I need the longer travel ones or std type..
Fabo
HappyDaze - April 9th, 2014 at 09:23 AM
You may have to up-grade to K&L, Chris.
Craig Torrens - April 9th, 2014 at 09:26 AM
Wow, mine are still good after 15 years of racing.
Were they put in the correct way with the gaps in ball joint lining up with marks on the arms ?
Did you setup the front suspension so the ball joints weren't at the end of their travel at full suspension compression ?
What brand of ball joint did you use ?
cnfabo - April 9th, 2014 at 10:58 AM
Originally
posted by HappyDaze
Nnooooooooooooooooooo!!!!!!!!l what u talking about,I seem to have seen the no#8 has hiem joint/no longer swing axle,lol
cnfabo - April 9th, 2014 at 11:08 AM
Originally
posted by Craig Torrens
Were they put in the correct way with the gaps in ball joint lining up with marks on the arms ? Not sure but the they move forward and back 90 to the
tube on the trailing arms
Did you setup the front suspension so the ball joints weren't at the end of their travel at full suspension compression ? Shop just pressed them
in.did not know that u can press them in any different angle...I'll go have a looksie...
What brand of ball joint did you use ? Would not have a clue..
Fabo...
matberry - April 9th, 2014 at 11:25 AM
If aligned properly, as Craig said, they should last for years. Quality of the joint is my opinion. Even some German joints are crap. I use
specifically Febi with gold anodising, the silver cad plated ones can cause issues even though branded Febi.
matberry - April 9th, 2014 at 11:26 AM
Also on B/J front ends, the shock length and suspension height/bumpstop arrangement is imperitive for handling AND longevity
HappyDaze - April 9th, 2014 at 11:47 AM
Originally
posted by cnfabo
posted by HappyDaze
Half right, Chris....I've replaced the link pins with rod-ends [to give camber adjustment], but the rear end is definately
swing-axle.
cnfabo - April 9th, 2014 at 01:22 PM
Originally
posted by matberry
I think I must of got crap ones also..where do I buy the good ones
cnfabo - April 9th, 2014 at 02:44 PM
Originally
posted by HappyDaze
posted by cnfabo
posted by HappyDaze
Half right, Chris....I've replaced the link pins with rod-ends [to give camber adjustment], but the rear end is definately swing-axle...its a
funny hump day today
matberry - April 9th, 2014 at 04:47 PM
Originally
posted by cnfabo
posted by matberry
Vintage Vee Dub Supplies 02 97891777
PAZZAN - April 9th, 2014 at 04:59 PM
yep
swing axle that dosn't swing any more
HappyDaze - April 9th, 2014 at 05:09 PM
posted by cnfabo...its a funny hump day today
No idea what you mean...
HappyDaze - April 9th, 2014 at 05:14 PM
Originally
posted by PAZZAN
yep swing axle that dosn't swing any more
