Just come back from a double header at Croft.
Race 1 (wet and long)
https://www.youtube.com/watch?v=cF7ChAZoIv0&feature=youtu.be
Race 2 (dry and short)
https://www.youtube.com/watch?v=5e1wbUMPMAk
Great stuff, thanks for sharing
Thanks Ian; can't believe you had a wet track in England!
Pretty good effort, pompom.![]()
Like you, I like the wet. This was in 1963.....I managed to beat a very quick Downton Mini that day:-
I don't know about liking the wet, but in the UK you don't have a lot of choice!
I used to hate it, but now i've done a few wet races i'm starting to gain confidence. I do need to learn to use less steering lock and turn the car
using nothing but the gas pedal...takes practice (and balls!) to get it right but i'll get there.
I also need to sort the gas pedal out, as I was unable to heal & toe which was why the downshifts were so poor in the wet! (you must have noticed
me snatching the rear)
Here's the next video offering and unbelievably...its raining!!
Oulton Park Gold Cup (2 races)
https://www.youtube.com/watch?v=bAfdyWBd9WY&list=UUcjAhwWO65zKiIzhOncRjdg
Awesome; certainly had some understeer in the conditions!
Very cool!
Plenty of cars to avoid
Hi Pompom
Very great stuff!
I used to race against some classic Minis with my VW 1303. Looks like I didn't drive as good as you even I had bigger engine (92x74mm) and more
sophisticated front coilover struts/IRS setup. The fast Minis could do 3 to 4 seconds per lap faster than me. My best lap was 1'44"
https://www.youtube.com/watch?v=9tZ9wb6clkg
I am planning to build my next air-cooled race car which will be a shaved weight Karmann Ghia (fibreglass front and rear ends) with 1300 or 1600cc
engine. It would be great if I could learn something from you about tuning small displacement VW engine.
Tim
Hi Tim, love your movies. Nice to see historic racing in China with Minis, Anglias, BMWs, Alfas (and so many Beetles)
I have 7 Minis in my class (in the dry 4 are faster than me and 3 slower) I can match them on the brakes and in the corners but my biggest problem is
i'm 50kg heavier so the Minis have better acceleration so they can be up to 10mph (16kph) faster on the straights.
If you build a 1300cc race engine like mine the 77mm bore is too small so you cannot fit big valves which drastically limits the power. (my
regulations limit me to 1300cc) If I could go bigger I would go for a 1641, 1776 or 1915cc that revs to 7500-8000rpm
Keep in touch
Ian
Hi Ian. How did the porsche fan go in comparision to the electric system you ran before?
Hi Ian,
The movie featuring those mixed makes of cars was in Thailand (street circuit). Unfortunately historic/classic racing is still not that popular in
China although other motorsports of modern cars have been developing very well.
I want to build a small engine because the race I am going to take part also has class limit. I plan to enter Class A which restricts to under
1800cc/1000kg. If the engine is 1300cc, the race car can be lightened to about 700kg. If 1600cc, the weight has to be around 880kg (about the stock
weight of VW Type 1). If 1776cc or bigger, I will have to enter higher class to race against those mighty Porsches, TVRs, etc. So it might be an
advantage to stay in Class A if I could tune a "high" power 1300cc engine and reduce the weight of the car as much as possible.
The heavily modified Minis are really fast. They could have 160hp with less than 650kg body weight. Your Beetle is only 50kg heavier than Mini? So it
is about 700kg or so, right? Any goods advice how to lighten a Beetle? In my case, a Karmann Ghia, which I have already bought some fibreglass
front/rear ends, doors and bonnets, etc. but I am not sure if it can be drastically lightened.
I also have a full race Mini with 1275cc engine which I lightened to 580kg (without driver and fuel). I personally prefer driving Beetle to Mini on
race track though.
Tim
Hi Tim,
The weight limit for my class (1151-1300cc) is 720kg (including driver) so the Minis I am up against have to add weight to get up to 720kg. The Minis
have around 135-140bhp. I am currently 770kg with 126bhp so you can see my problem.
For your rules its quite a difficult decision to make. My engine has roughly 100bhp per litre so if we use 100bhp/litre as a rule:
1285cc = 128.5bhp 700kg = 1bhp/5.4kg
1584cc = 158.4bhp 880kg = 1bhp/5.5kg
1776cc = 177.6bhp 1000kg = 1bhp/5.6kg
As you can see, mathematically there isn't much in it. All three engines would result in a similar power to weight ratio. It will be easier to get
100bhp/litre out of a 1776cc than a 1285cc and by adding weight to get up to 1000kg you can place the weight where you want to balance the car. On the
other hand having a 1285cc/700kg combination means that the car will be as light as possible (good for braking and handling).
All things considered the 1285cc/700kg option should be marginally quicker with better braking and the lighter weight will allow you to throw the car
around a lot more.
But bare in mind that reducing weight costs money and adding weight is cheap, so a 1776cc/1000kg option would probably be cheaper.
Good luck making the choice
Which make shroud are you using ian
Thanks Ian. Your analysis very makes sense. I think 1584cc/880kg would be a good compromise among, bhp, weight and cost.
Here's the latest onboard from Brands Hatch...Fanbelt problems again...Boo!
https://www.youtube.com/watch?v=dNWTt_NPWcg&list=UUcjAhwWO65zKiIzhOncRjdg
Damn I love watching your vids ian...what outside air temp and oil temps you running with the new Porsche fan ??
What sort of HP,weight ,cc are those Hillman's running.....
Fabo
The day was around 20 degrees and the oil temp is around 110 degrees (The stock cooling and my old electic cooling were up to 120 degrees)
The Imps are putting out around 115bhp@9500rpm from a 998cc engine. They are also 100kg lighter than me.
If you notice (despite having an ATB diff) i'm spinning up my tyres out of the corners which is costing me a lot of time. The Imps are getting their
power down really well.
Since removing the front anti-roll bar the front end grip is great, but the car obviously rolls more. The downward travel of the rear suspension is
limited by the Z-bar so it will not go into positive camber.
For a quick fix I have two choices I guess...I can put a stock anti roll bar on the front which will be soft but control the body roll, or lengthen
the Z-bar rods to allow more downward travel at the back to stop the rear wheels lifting...or both!
I'll have a dabble at the next race at Silverstone in a weeks time.
I've never considered hillclimbing or sprints but I will be doing more drags and I'll be entering the UK version of bonneville next year to set a top speed record for a 1300cc.
Top stuff. I love this car. What sort of problems you having with the fan/belt?? Is the fan coming off with the Porsche fan? I found I had to reduce my pulley a fair amount to get the fan/pulley ratio right with the amount of revs I do.
I use a 102mm bottom pully to get it to work effectively on my bug with a top end rpm of 8000
