Steve carter has just done 226kph (1st run) in his WRX powered beast at the Snowy Mountains 1000 (1km drags).
Steve Muller has clocked 172kph in the Roo Shooter.........not bad for a brick on wheels !
Sweet!
good results guys! would have given a few v8's a surprise!!
226 hey Carter, you might need a bigger turbo for Wakefield next year......
Plenty of quick cars there.........like a new Jeep Grand Cherokee getting close to 300kph
and a new skyline at around 320kph.
http://racing.natsoft.com.au/635927810/object_341220.73D/Result?8
Yeah.... Monster twin turbo from memory. That jeep is incredible, but the Willall GTR will destroy all before it
it has a VW connection too.....
hi Steve, I was reading Dave's calcs on FB and looks like you were only in 3rd gear? Is that right or did you get to 4th? Will be interesting to see your vid which I am sure you will post....
Videos coming, I won my class.
Top work Steve !
Thanks video http://youtu.be/spgKInSH1D0
Top work Steve.
I noticed the HUD gave up at 174km/h
Cheers Col
Pretty quick, Steve.....wouldv'e been even quicker if you took the junk out of the glove box.
I agree Greg but you need an Ipod to listen to on the return road, forgot to mention that Steve Muller won his class as well
Well done Mr Carter! Awesome.
Does the car feel stable at that speed?
Thanks guys, the car felt planted the whole time even when we had a strong cross wind
I had to use 4th, when the intake temps came up around 1/2 the ECU dropped timing so didn't want to rev so I stuck it into 4th
