Found out today that the classes at AHC are a bit different than what's normally run at Mt Cotton, and that Jezebel will need to meet the regs for
Improved Production.
The main change I have to make is 15" rims rather than the 16" Fuchs I normally run... plus put some steel guards on the back... so should be able
to get it done in the 2 weeks left.
Anyway I figured try find out what tyres, tread widths etc. other bugs run with in Improved Production... then I can start the ring round and see what
the $$$ hurt is going to be...
Tell us a bit more about the regs Dave.
I am at the beginning of building my beetle to do just this and don't want to do it twice if I don't have to
Appreciate your experience... I am also a Brisbane boy
vassy
Dave, you will also need to put the original bumpers back on.
You can now run 50 series tyres in the class, which is worth about 1/2 to 1 sec quicker times per track.
Jump onto the CAMS website and then go to the "manual" section for all the regs
I would run either a 205 / 15 / 50
or a 195 / 50 / 15.
You can only run a 50 series tyre on 15 inch rims, other wise its 60 series on 14 inch. (max rim width is 7 inch).
dunlop, toyo, kumo, yokies, bridgestone are all good tyres. Have a look on the CAMS web site and have a look at the approved tyres for the imp pro
class (for hillclimbs - the circuit regs are slightly different again).
Thanks for comments guys - much appreciated.
After several re-reads of the Improved Production regs I think I'm getting there. The thing that caught me Vassy was that at Mt Cotton they normally
run a Road Registered category where things aren't so controlled as imp pro - it's basically any Category 3 car that's properly road registered (I
think club plates tho are excluded). I log booked as 3C Rally Car Other, so road reg suited me fine since I had wider guards up back, bigger rims and
so on, and I was more out to have fun than be competitive anyhow. But for AHC they're running exactly by the CAMS categories, and to be honest I just
don't want to miss out on 3 days of racing.
Thanks for the tip about bumpers Craig - have had that sorted for a while, but I definitely don't like the look of the car as much with them on.
I think 195/50 up front and 205/50 rears is what I'm going to go for - prolly just a mental thing, but I've always felt happier with slightly more
rubber on the back. Looked at the measurements tho, and the 15's are going to end up being A LOT smaller OD than what I've been running up till
now..."bring it on" for slightly better times, but might have to reset ride heights a bit first !!!
I have a set of 205/60R15 on 7 inch steel rims if you need them.
Also once i get the 6 ich rims powder coated, will have a set of 195/55r15 in toyo r881 (got the tires if you have rims to run them on)
Looking at a set of 205/55r 15 for the hillcimb next year.....
Changing tyre size changes your ride height, handling characteristics, gearing and speedo reeading.
A lower profile tyre usually gives you shaper turn-in and less flex in the tyre which translates into less body roll.
However lower profile tyres can give you less "feel" as they will let go more suddenly.
I'll list some overall diameters which may help the size choices:
560 - 15 cross ply =633mm (Standard beetle)
165R15 Michelin XZX = 646mm
205/60R15 = 627mm
195/55R15 = 595 mm My preference becasue Yokohama don't make a 195/60R15 anymore.
205/50R15 = 587mm
195/50R15 = 577mm
205/60R14 = 602mm
195/60R14 = 590mm
Now for road leglity and insurance requirements you normally have to keep the diameter within 15mm of the original equipment tyre. So the window for
alteration is 618 - 648mm.
CT
But racing cars are quite different.
Sides, you may have to run in Sports Sedans if you really want to leave the bumpers off. Brutus had no choice as he aleady had wider fibreglass guards. The positive side of being in sports sedans is you can almost do what you like as far as mod's go, with no questions from scrutineers, or complaints from other competitors. In Vic the sports sedans times are usually similar to those of the Imp. Production guys anyway. We don't regret being in S'Sedans, but if there were any other VW Bugs in Imp. Production (to date there aren't any) it maight have been a shame.
I'd thought about the road legality, but only very briefly as I don't plan on running these tyres + rims on the road. Here in QLD it's +15mm and
-26mm on the overall diameter of the tyre, which my 16" rims fit within nicely (as do the road tyres that I'm going to have to take off my 15" rims
incidentally).
Question though CT - is there a document or link that covers what sizes Yokohama do for their motorsport tyres ??? My thinking is that if I ever do
any circuit racing I'm going to need A032 or A048's on, and since I don't really want FOUR sets of tyres might be easier to get Yoko's now and be
done with it.
And yeah Brutus - I had thought about just going Sports Sedan, but the thing that knocks me there is the requirement for 2 anti intrusion bars each
side in the cage... my cage only has single each side, and Qld Transport rules don't really allow for a second one cos it hampers entry/exit. Also no
other beetles running at Mt Cotton regularly yet, but hopefully that's gonna change soon...
Give it a year and there will be another beetle running at Mt Cotton.
Not planning on registering mine at all though. Will be interested to work out all this class differentiation and settle on what I need to conform
to.
Just got a nice 54 oval body to put on the BJ IRS chassis I already had. Lots of work to come but the excitement is building. I should be able to make
it across for some of the racing and look forward to seeing you there.
I'll send a pm closer to the day when i confirm what day I will make it.
vassy
Hi Sides,
R-spec tyres like the A032R and A048 are pretty versatile. They can be used for hillclimbs, supersprints and tarmac rallies and the Yokohama's are
DOT approved and road legal.
So you could get away with one set of tyres for everything you do.
I've used my A032Rs in supersprints last year, the Dutton Rally this year and I even drove from Sydney to Warwick on the fronts.
The fact that they last quite a while on a light low powered car is a good thing but it's also a problem. It's really hard to get R-spec tyres up to
their proper 60 degree operating temperature. Your car needs to be set up well with new shocks and the right spring rates to get the most out of the
tyres.
I think the A032Rs are only available in a couple of sizes now. There are still some 195/55R15s and 205/60R15s in stock. The range has mostly been
replaced by the A048. Unfortunately for those with light cars that do short events the A048 compounds are mostly one range harder than the A032R range
and each size only comes in one compound.
I could crap on for ages about these things beacuse they're quite complicated to get to get rigt.
Some of the A048 sizes are:
185/60R14, 195/60R14, 185/55R14, 205/60R15, 195/55R15, 205/50R15, 225/50R15, 195/50R16, 205/50R16, 215/45R17 and 225/45R17.
These are available from Yokohama Motorsport Distributors listed at the bottom of this web page http://www.yokohama.com.au/motorsports/
They ain't cheap but the cost per kilometer is good.
Regards CT
Hey, i'd be great Vassy to see you there, and even better on the track as a regular thing !!! BiX is also Brizzy based, and has had his car in an
"almost ready" state for a while now... hopefully he's going to run at the December round.
Thanks for the info CT - it's all good suff to know. I know what you mean about being complicated to get right - was stunned last time just out how
big an effect 1psi difference in the starting pressures made. I'm tryin to be as thorough as I can and change only limited things at a time, record
results etc., but I know I've got a fair way to go yet to get the most out of things !!!
Thought I should round this out with what I ended up doing tyre wise.
I checked out the pricing and availabilty on the Yoko's on your advice CT, and it was just going to be too tight on both timing and budget this time
round. Ditto the Toyo's down in the 195/50/15 and 205/50/15, so on advice from some of the other regular hillclimbers up here I went with Kumho's at
185/55/15 and 205/50/15 in the medium compound. The Kumho's seem to be a bit softer than the Toyo's that I'm used to, and also seem to be able to
run them at a lower pressure without getting that dreaded squirmy feeling when coming off the top of the first loop. That could just be warmer track
and air temps too.
Craig was right on the gearing - big enough difference to be noticeable before even getting out of my driveway. Combination of changes improved my pb
time by almost bang on a second - hard to say how much was down to the gearing change, but definitely had more pull going up into the loops.
Also finally got round to putting the 28mm torsion bars in the rear since had to reset the ride height anyway for the shorter tyres. I'm now getting
mild oversteer, but really pretty controllable. Going to hoipefully stiffen the front up some before the next round to get back to neutral - I'm
still re-learning how to drive volksy's quickly and am finding even little things make a big impact on my confidence levels, so we'll see what
happens.
