Just spent the day at the holden vs ford drags at WSID. Great day and lots of very fast cars there. Makes me think.
The fastest NA VWs in OZ struggle to break 9 secs.
Yet the faster NA V8s are in the low 7s.
I'm not slanging out our serious NA racers (my hats are off to you), I'm just wondering what it takes to make cars do 7s, and why it is that VWs
struggle?
Can Dangerous or Boostn help me out here? I love drag racing, but I have no detail knowledge about it.
i am sure the experienced boys will be more precise, however i will throw a couple of reasons out there..
Big v8's can make silly hp and naturally torque. There are also endless manual and auto gearbox/diff options to choose from that are strong, reliable
and resonably priced. Combine that with a tubbed rear end and slicks..
Matt
A 1600 VW engine has around 60hp i think, a Ford 351C makes around 250hp(2v) in standard form...
I think a 4cyl aircooled car 'struggling' into the 9's is awesome.
The V8's have just had so much more development done and are a better platform for making power. So comparing VW to V8 prostock style cars they have roughly 3 times the displacement, 4 times the hp and only 1.5 times more weight! do the maths! And there hasnt been a 9 sec NA pass in aus yet has there?
The answer is cubic - dollars and displacement. Also check under the bonnet next time youre at a Ford/Holden day as the ony 'street' guys I know of in the 7sec zone N/A in Aust are Trick and Mansweto in their Capri .
the simple answer is theres no substitute for cubic inches or capacity
If you could make a VW about 200 Kgs with a decent engine you could proberly break into the 7 or even 6s
Power to weigh is the answer
Mark Hayes in the light blue LC torana runs a 632 cubic inch big block and 400 hp 2 stage nitrous kit.........he got 940 hp on the dyno N/A without
running the nos at the last summernats
and he's driven it from castle hill to wollongong :duh
basically cubic inches and power to weight ratio is the key
mmm, so how big does a type 4 in a beetle need to be to compete then?
Crikey 777 hp at 1700lbs !!!
Might be a bit tricky to extract that from a VW NA !! I would guess with the revs required you would need 4 valves per cylinder and hydraulically
operated valves ala F1... As for heads ?
