hey guys ,i was considering putting a turbo on my 1200 62 baja ,i dont want to get a bigger engine ,is there any links to the topic or any info is
apreciated ,,,,thanx
i can make all my own mounts manifolds and pipework ,so thats not a worry
theres a lot of big mountains up here were i live ,so its mainly for a bit of help on the ranges ,and a little bit of fun off road
[ Edited on 24-5-2007 by stacy b ]
a 1500/1600 is cheaper than a turbo setup. it will also last longer.
sorry to rain on your parade, but i figure you want the truth.
Prolly a cheaper way is go to say a 1641 but use the single port heads with say a single 40mm weber. Done this a lot and they will get down and pull and very low rpm. not a big revver but offroad you don't really want that.
come on guys ,i can buy and rebuild a secondhand turbo and fit it myself and pipework and manifolds for half the price of a decent 1600 engine ,what
would be a good size for a standard 1200 ,please anyone
I've got a T2 off a nissan pulsar on the TAT turbo. You wouldn't want to go any bigger than that.
2nd hand turbo's at the wreckers start at $250 when i inquired last week...
only major cost is time...
im watching a few on ebay ,just hoping i can be lucky and get a easy rebuild or theres some that were just changed so the owners could upgrade ,
I think you'll find that by the time you bend up the exhaust, weld everything up, get a carbie fitted and fit a larger oil cooler (which you will
need), it is actually cheaper to buy a decent 2nd hand 1600. If you look around I think you'll find a 1600 for as little as $300, which is much
cheaper than a turbo setup for your 1200. Once you have the 1600 in the car, THEN TURBO that motor. Or buy a 1600 which needs a freshen up and build
it with the purpose of using the turbo. You might even get a worn 1600 for nicks if you look hard enough.
Coz you won't be satified with the 1200 for long, even with the turbo. Sell your 1200 off to some guys who are into early cars. 1200s are becoming
harder to find parts for and so are worth dollars.
It would want to be a very strong 1200. I'd definatly have all the valves in the head replaced with new ones, as i've seen too many exhaust valves
fail from normal metal fatigue, let alone what will happen to the poor suckers when they are glowing red from the extra heat the turbo will make for
them.
The turbo you want is called a GT1752. They are from a SAAB 2.3lt 6 cylinder, and run from the first 3 cylinders only (1.3lt of exhaust flow). The
have been used with good success on the 1.1lt charade's from what I hear. This is as large as you want to go. It would make boost from about 2200
rpm, full boost by about 2500.
If you want a lot more low end torque i'd be looking at a GT15 or even a GT12 turbo.
The Nissan EXA T2 is WAY too large for a 1200, especially for offroad use IMO.
Expect to spend some $$$ on this project. Turbo's aren't cheap or simple.
Still interested? I have one a new GT1752 forsale for $350. Its brand new. I was going to use two of these on my engine, but decided to go larger
again.
Cheers,
Ian
fuel presssure reg + fuel pump + oil cooler + bigger fuel lines + oil lines and fittings + all materials to do it = $$$. Buy a 1600.
A turbo 1200 is a waste of time IMO, T54
yeah but help her do it ,and as she progresses then help her do it in a 1600 etc all the way to a 2332 efi intercooled baby
thanx guys ,i just cant find anything around this ara from tamworth to armidale to gunnedah ,thats worth paying what people want for them ,,,the cheapest ive found is a 1500 that needs a full rebuild and they still wanted $400 for it ,,,,
I'm thinking source a 1600 single port and build the engine up out of the car. Make it all 100% and keep the 1200 as your backup engine. Wibble off
this forum can help you out with a side draft 40 IDF webber that is in perfect condition that would make an ideap carb for a pull through turbo
arrangement. Send him a U2U.
There is a bunch of "turboing a stock 1600" threads on the http://www.shoptalkforums.com forum in the forced induction section that are worth a read. They have made some pretty
reasonable power too for what is essentially stock engines. Enough to rival a built 1916 NA engine and then some.
she is a he..no?
No disrespect, i just checked out the profile.
Jason & Stacy......two VW lovers.....one account....
hi nuts dont you recognise the addy,i had too use the missus name ,i wanted to use jasonb but i said there was allready someone with that username
[ Edited on 25-5-2007 by stacy b ]
Aah, all clear now...back to the turbo 1200.
I was just thinking, why not find a cactus late type 3 (wagon is best) and buy that for a few hundred dollars. Then you get all the IRS components you need for a real Baja, plus a 1600 with twin carbs that you can convert to upright (or leave as is, it's a Baja after all). The discs on the front can be machined so they will fit king and link pin and the drums late drums can go on the back. The brake upgrade means an instant ok from the engineer when you get it done. You have everything you need to have a great baja. If you want to turbo it later then you can do that too.
ok guys ill put a swap add in the for sales and see what i come up with ,if i get nothin ill stick with the 1200 and have a little play ,i spose thats all i can try ,,,thanx guys
hey pete that is great adivce thanks .. man i think the baja thing is becoming stronger again.. and great way to get the bits with out spending a fortune
good on ya kroozn. go get dirty...if you know what I mean
so ya can run a type 3 donk without the upright gear in a baja
Hi peoples
I have seen Type 3 and Type 4 motors in standard set up running in a BAJA and Buggys.
Marc
I wouldn't run a type 3 setupas the motor will run hot. I have experienced this. So speaking from experience
BJ
Upright a Type 3 donk as their standard cooling system is notorious for running hot on the side with the oil cooler from memory.
