Just bought 56? splity for my new race car.
This will be a slow build as you would expect, and thinking of starting n/a 20b, yep my current trusty bridge port minus the turbo, but running on
alcohol.
Time to bring out the old 091 4speed box, not the best ratios but should be up to the task because this set up won't have much power using the
original plenum and throttle body. Should be loads of fun having a purpose built drag car insted of a street/race car.
I'm still racing in Thomas at warwick this year but using pump fuel, and 7-10 pounds of boost.
Hear are some pic's, from to day, can't wait to get it home to start working on it.
Nice one Aaron - so what will take the priority (the missus' type III or the splitty??) hehehe
Al
Nice!!!
Hi Al, it's only fare to finish the type 3, as i already have a vw or two that go. The splitty can wait a little, but still have to start to plan the
drive line, roll cage, ect. (wheels, stearing wheel,,,,yeah everything)
I'm thinking 2010
nice, i shouldmhave an ej20t bug by then so that would be a cool run
best of luck with the build.
Stephen
You are friggin nuts dude...and I LOVE IT!!
Can't wait to see the build progress.
You NUTBAG
hehehehe looks like fun
i love you other kombi mate ![]()
Aaron, looks the goods, with the weight difference between the bay and the split the n/a 20b should still go pretty well but still cant wait to see the finished project when it turbo and a nice 800hp, should make a interesting ride!!Make sure becks t3 is ready for warwick, the grudge run is on!!
Aaron that will be very cool!!
Are you going the whole hog and tubbing the rear for some big slicks and dumps it on its guts ... whatever you do I am sure it will be an excellent
result
Mate now I will have to get some more funds to buy some bigger go fast bits seeing as you are going to get lighter LOL
All motor.... bay vs split....... VW vs Rotary........
"this set up won't have much power using the original plenum and throttle body"
Apparently that dude with the 9.4 second A/M mazda down south uses the stock manifold. (!)
I belive there are people who port the stock manifolds with good results.
thats what I've heard on the mazda streets
I'm guessing a nut or nut bag is good??
Finally got the bus home to meet the vw family,
As usual it needs more work than i first thought, thats ok, I'm still excited. I think the youre right , the rear end will be the largest amount of
work. I have about 4 designes that im working on. The motor and box will have to be able to be removed seperatly, but still will be tied in to the
rollcage as well as the torsion beam. Thinking coilovers insted of previous air bags so i can adjust the spring rate. Dangerous has a pare of 28 x 9
slicks that i may use which should fit under the guards.
Picking up a 68 front end and the old box and axels tommorrow. Only the front end will be used with a disk brake up grade. Rear will have disks to.
The mazda 'sheriff' has run 9.4s on alcahol, but is a p/p and has aftermarket plenum and a single 3.5 - 4 inch throttle, making around 400rwhp. I
will port the 20b manifold in this engine, un like the current 20b turbo that i left stock.
There is heaps of alloy that can be removed from the upper and lower manifolds, Ive done this with my old 13bt setup.
I guess that it slould make around 300hp
Brennden, we should swich buses then your young bus may have a chance,,,, 'big fella'
Hay Troy, Bec said bring it on!!!!
Thanks for the positive feed back guys, being non vw powerd and all, as you are all such vw enthusiasts.
Rota's and VW's... to two favorite automotive things!
What do you run a 13bt in???? What does the family of cars consist of???
1984 series 4 rx7 13b turbo engine was originally in the black bus which made 187hp@ wheels
Then i rebuilt it, which i large extend ported and a T04B turbo 280hp
Then i pulled it down to bridge port and a TA51 turbo 403hp 13.2 @ 103mph 1/4mile
Then 20b n/a 201hp 41mm throttle body
Then 20bt T04E turbo 430hp stock block 16psi 12.1 @ 118mph 1/4 and 7.63 @ 91mph 1/8
Then 20bt TA45 turbo bridge port C16 fuel 570hp 6.89 @ 102.7mph 1/8
My family
64 type 3 notch blue (percy) 1600
65 type 3 notch deluxe blue (toby) 1500
65 type 3 notch deluxe yellow (sally) 1500
66 type 3 notch greeny brown (gordon) 1600 originally was going to be 13bt race car
66 type 3 square green (rusty) 1600
70 type 3 square 1/2 car for parts
71 type 3 square will paint orange (clarabelle) 13btwin turbo 198hp 7psi changing to T04E and an intercooler
72 type 3 square multy colour (ratty rat bag) 1600 for parts
76 kombi black (thomas) 20bt bridge port
76 kombi micro bus (mickey) 2L
2000 T4 transporter (dan the van) 2L
56 kombi no name yet will be 20b n/a race car.
have owend others to, but no longer alive.
Nice collection. good to see some are still original! Where do you find the space????
Im guessing you work with cars for a living?
Question... isnt a series 4 post 1985?? I thought 84 for still series 3... and I didnt think any aus delivered series 3 were 13bturbo...??? I may be
wrong
..........nicest bloke one could ever hope to meet...........BUT definately "nut bag" Aaron, sorry
for sure you will do the ol splittie justice and will be all kudos to you again, can't wait to see it progressing
exhibit A...
http://www.youtube.com/watch?v=vhcCCi3UVpU&feature=related
Sorry wrong key, yes your right 86-88 FC series 4
JMOBFC!!!!!! nice. A year at mazda wasn't a complete waste for me then
Id love a rotary beetle... or... an sa22c. too expensive for me. one day though...
I really respect what you do, its awesome
Gee... thanks Daimo, I would have to say the same for you, and as for the nuts, well,, somethings got to hold the front of the kombi down.
Jason, I have a bouble block 4 car gararge and a 2 bay car port still not enough roofing.
I'm a cabinetmaker by trade, motor homes, 40-60ft cruisers, house hold cabinets and owned a shop for 2 years. I'm self taught for all automotive
stuff (and spelling). I've worked at mazfix for 9 months but didn't lern anything new apart from sales. Still doing other engine convertions and
rotary rebuilds from home. Also do courier driving.
Why not join the dark side, and make make what you want?
The splittie better be kudos, after all the work i'll do.
I'd so love to put a 20b in a bug - maybe mid mounted even... maybe in vwrx even (already have the porsche box in there).
Really like your work dude, particularly the wheel stands in a kombi - something you'd last expect to see them from![]()
a 20b is a bug would be INSANE. and scary as anything. look forward to meeting you at warwick this year Aaron. I Took some photos of the black bay
last year I think.
Need inspiration?
Not set up for the drags but cool nonetheless.
Al
nice.
always a fan.
but enough with the chit chat,get cutting.
i can't wait to see how this one turns out.
Great stuff Aaron. Will look forward to this build up. Hopefully you'll stay with the same colour scheme.
I must admit your bus has made me look at rotors differently.
I even let Ben bring his over now....although it has to stay out of the yard....small steps..
Sorry readers, I'm not alowed to spend much time or money on the bus until i've finished bec's type3 and done some more on the house renovations.
So I laid tiles for two days and worked on the type3. Still working on my brothers 78 bay , EJ20 convertion, 2L auto ect.
I'll have to sort all running gear, tyre hight, body hight, wheel track front and rear, engine/box position, fuel tank position, rollcage, suspension
location, all has to be done befor i start work. I don't want to redo much on this on this bus, unlike the last one. Want to plan for future
upgrades, if posible.
I love different ideas so don't be afraid to post them up.
Thats a very tough looking bus alan. One of the best i've seen, pity it's not for the drags.
Thinking of mat green and mat cream on top, stock front rims cream, a bit retro, mabe???
Stanley, glad to see your comming around. Hows your son's kombi going? Send him round and we'll bolt on what's missing
I'll have to see his set up, and go for a spin.
I'd like to think that a later upgrade might even include a blown big block Rodeck ... I'd like to see a 7sec pass out of a splittie.
You can't have too much speed!
7's are still posible with a rotary, but that's to fast for me. Only looking for high 10's to start then someware around 9's later. Shame on you!,
v8?? rotary
way too fast.... but cool as.
