I am listing these for a friend situated in Sydney, sorry no pics.
Please contact via telephone during business hours for details.
All type 1
Name; Dave
Phone; 02 4625 4244
Complete turbo system,good for 500hp
2 wastgates
1blowoff valve
1 dump pipe 3”
4 bolt flange exhaust complete(will fit 2bolt heads)
All pipes h.p.c. coated
With a dial-a-boost if you need it
Turbo in good condition,bolt it on and go really,really fast
$1650.00
Turbo cams
Flat tappet steel ,surecam grind,with lifters $350.00
Autocraft 600b 1meeting old $300.00
Steel roller serious h.p.cam p.o.a.
Autometer pro-control with rev-limiter 5301 $185.00
Albins close ratio gear set
3.10,1.93,1.25,.93 $750.00 SOLD
Autocraft 910 heads to suit 4.030” bore,titanium valves,springs etc $800.00
9+1.25autocraft ratio rockers $220.00
2+high tensile rocker shafts(tapped on ends ) $45.00
4+48s/steel inlet valves $100.00
4+38 s/steelexhaust valves 100.00
1 set collets&lash caps tosuit above $45.00
1 set berg collets &lash caps $45.00
1 set k800 valve springs new with retainers $80.00
1 set berg retainers $30.00
1 set chev retainers $30.00
1 set berg adjusters vw style 45.00
is this stokers setup?
Yep
Hi Matt, I'm interested in the gear set....will send you a PM.![]()
Albins gears sold
Gotta be quick round here ...
any photo's of the turbo setup ?
Surely someone has pics of the LMS drag car system as thats where they're from.
hay matt.........K800 are "chevy" size springs yeah??.........if so i'll take em and the berg collets, retainers and lash caps if they match
whats the autometer pro control all about?
PM sent
Ring Dave, phone number on the firs post.
