I'm after a Lexan Window Kit for my 56 Rag Top Beetle, so I'm after a little info on where you got yours and what you paid etc.
Any Australian suppliers ?
What have you used as an alternate product ?
Currently looking at the Cal Look window kit, because it requires no drilling and uses stock rubbers etc (looks road legal).
Any advice is appreciated.
rod penrose had a set in his 1303 at Wakefield, meaning he might have some recent info on them
image plastic's has it on file.
don't know the number,they are in padstow.they don't have the 1 piece front's they are 2 peice.and the oval you would have to trim yourself.just
tell em westside sent you.
Plastics supplier and a jigsaw
use your old windows as templates, couldn't be easier really
Sounds good i got a lot of window weight to get rid of in the bus LOL
Thanks for the info and the leads on manufactures. I've found kits in the states for around $650-700AUD landed. So I'm now looking to go with my
initial thoughts and make them myself.
Thanks again
just take your windows to any plastic supply company and they can cut them to shape- were i get it done in adelaide they even bend the rear window to
make fitting easy- it cost less than $200
adam deb
