Hi was wanting to get an idea of the types of nitrous setups some of you guys are using?? Is there a plate system for webbers? any input greatly appreciated cheers
im running ida's, i will make some calls today about a plate system not to sure if there available. Im thinking I will have to run a fogger system like you mentioned. Anybody have any pics of there systems plumbed up??
If you were running a plate type system on a bug its not real pratical when it comes changing the pill/jet as the pills tend to go in each side,fuel on one side gas on the other there is allways something in the way fan shrouds fire walls etc,same thing if you squeeze the fogger nozzels in.You could check out dak-attacks web site and check out how he installed his.And a little tip two fuel solinoids are the go on a flat motor mounted close to each manifold as if you have 1 fuel and 1 gas solinoid mounted in the middle and lines out to each side the gas gets there quicker than the fuel and creates a lean situation until the fuel catches up or you blow shit up!Mcdonald brothers/oz noz are in melbourne pretty close to you they might be worth a call.
cheers for the advice cole. I did talk with the guy from oz nos today, He can do a webber plate kit but not in the idf/ida pattern. He has built kits for a few volksys and had a few interesting ideas. Im thinking I might just have to put together my own kit by purchasing individual parts! Like the 2x fuel soliniod concept.
have a look at brad's (westside mufflers) setup, he has the foggers plumbed up and looks good... if u cant find it on here i can probably dig up a pic for u
thanks reub, saved me going though 200gb of pics to find
You have probably already seen this site but if not....
http://nitrousoutlaws.com/forum/index.php?board=2.0
I found it pretty helpful...
cheers for the info guys, ordered some new M/T slicks for next meet so cant wait to see what happens!!!
