JE forged piston 92mm / air cooled, what sort of cylinder clearance. This is on methanol and track only.
They should have a spec sheet with them, but i would like to see min .005".
Boost? probably up to .010"
No boost Dave. Thanks for that.
Yes.
send us a link to the site and clearences
Please.
Here are the specs required for the two different materials.
You can use the JE pistons website to work out what you have,
but as mentioned in my first response, it should all be in the specs sheet that comes in the box.
http://www.jepistons.com/PDFs/TechCorner/SCPDrawings/piston_instrc2618.pdf
http://www.jepistons.com/PDFs/TechCorner/SCPDrawings/piston_instrc4032.pdf
I always run a little more clearance with air cooled, or with boost as stated in the instructions.
But in a perfect world it should be fine with the recommended clearance they list.
The extra clearance can make it harder for the rings to do their job,
but a clearance that is too tight can be catastrophic(sp?).
