with the support & backing from Team WPVW , Cindy has decided to come drag racing with 'Billi' her 1965 model rat beetle
for those of you who dont know Cindy , she has been a team member of WPVW for the past 4 years . She raced at Warwick in 2009 in a blue 1973 L-bug
powered by a 1776 type-1 engine and also in 2010 in a red 1960 Karmann Ghia powered by a 1776cc turbo type-1 engine
this year Cindy plans to run her much loved 'Billi' at Warwick with a new 2332ml turbo injected type-1 engine
Billi gets 4-wheel disc brakes , a 2" narrowed front beam , drop spindles , a tandem brake master cylinder and all new brake hoses
Billi is back on her wheels and the brakes / steering feel great .
Now the engine & transmission parts start to arrive . WPVW bores the new engine case for the 94mm barrels and the case is clearanced for the 84mm
stoke crank
What computor are you running in it Wayne?
I can't wait to get there either, hopefully all the loose ends should be finalised next week, then onto the dyno.
Are you going to run an intake cooling system on this engine and what size turbo?
i will be cheering for cindy and billi on the side line this year, great job on the build.
looks like you could be up for fastest female with that combo,
and its a cool rat!!!
hell i think she could be quicker then alot of man ...me for one but i think most people will be quicker then me !
i hope you getting you hands dirty for this build!
O crap
will be good to see the rat in the finals
Don't admit defeat yet Rose!! It's all won on the start line with getting the light right!!
orders have arrived from US with engine and transmission parts included
engine assembly starts for Cindys' 2332 turbo injected engine
the bottom end is assembled
Turb oand engine set up similar to mine, cool, good to see the pockets are deep at the wpvw camp. Not much time left to get it going. Another Turbo car on the way, sweet. What fuel are you gonna run it on?
Hey Chris do u have yr Kleenex handy
hows yr car going
Cars coming along nice, and I've moved on to a mop and bucket
more engine progress for Cindys' rat-look beetle . engine bottom end finished , deep sump tapped for temp sender , pistons balanced
engine assembly completed , now the cooling tin and turbo system will be installed . New oil cooler and CB performance turbo header installed also
Good work guys![]()
more progress on Cindys' engine . The turbo header and cooling tin have been fitted and the engine fitted to my turbo oval to check clearances to the rear apron assembly . all looks good
more engine progress . CB performance injector manifolds and rails fitted .intake plenum being manufactured
more progress with Ciindys rat bug . Wiring of the microtec ecu and fitting of all fuel lines ,pump and filter . We found that Cindy is very handy with a soldering iron
engine ready for fitting to Cindys bug . Just have to get the transmission assembled . All fuel hoses and pump in place , all wiring completed in car ( just need to wire engine to plug at firewall ) wastegate and blow-off valve fitted
Man, I want this motor. I love it, well done guys and good luck with it Cindy you lucky girl
Wayne, since you got most of the gear from CB are you using one of their turbos. Also, do you know with the CB turbo exhaust system if it will bolt up
with heater boxes or only J pipes.
Thanks and keep us updated, Kev ![]()
After a lot of work billi's motor was finally started today. i will post video in the day or two. Now all that is needed is tuning then it will be ready for cindy to drive again. See pictures of Billi's new wheels - Santa was really good this year!!
