Thought i would use some spare parts form the garage to build a BUGGET race car to have some fun.
The idea is to keep the build cost way down and the maintenanece that doesn't exceed the auto's diff gears or case. But i still want to go as fast
or faster than my black kombi if i can.
This is some of the stuff from my parts bin.
1 x 66 vw notch
2L kombi auto
1800 auto diff gears (4.360)
4000 rpm stall converter
13b cosmo, s4 rotors (8.4:1 comp)
Microtech Lt-8s
6 x 1700cc injectors
3 x 910 bosh fuel pumps
malpassi fuel reg
M/T street radials (275 or 235)
2 x garrett gt40 turbos with .96 to4 exhaust housings
What happened to the Splitty?
I have already started machining the exhaust housings and spacer plates. The gt40's come with 1.18 (45 style), with would be to big for what I need
so i've machined the .96 (T04 style) housings to suit the bigger gt40 rear wheel. They needed 7.4mm spacers to mate them together.
Looking froward to watching/reading about this notch coming together
About freak in time Aaron. I've been posting type 3 pics to get you motivated. Will look forward to this.
Additionally, those rear over riders would look on my notch. Think of the weight saving....
Yep...it's yours if you want it
Here's some pics of the spacers to fit the small housings on the gt40's
T04 exhaust housing fitted
this shows how much bigger they are over a single 13b turbo. Together they should get a 13b spinning!!!!
I machined and polished the compressors too.
In the nicest possible way you're a freak Aaron
As usual top class stuff. Love looking at your work.
Ah, good work dude,
I'll take that gearbox off your hans to help the funds department.
So is the notch going to be flat black to keep it in the family so to speak LOL
what colour....flat black?
I didn't think the 1800 auto(003) diff gears fitted the 2L auto. Are the pinion shaft interchangable or are you changing the pinion gears on the shaft?
Yep, mat black with orange roll cage, stripes and wheels.
I just use the 1800 crown wheel and the pinion gear, not the pinion shaft.
The 2L diff center has larger stub shafts and planetary gears.
Wow...... I am so looking forward to this project progressing.... Huge fan of TIII's and Notch's in particular.... Will be looking forward to seeing how you make the rear end work with a horsepower injection!
At the moment I'm thinking of removing the 1966 3er torsion tube with horns and using 70's wagon
Tube and torsion bars, and kombi axles and bearing housing with extended tube diagonal arms.
Also make the spring plates longer.
I'll start with kombi c/v's and go from there.
Yeah I know, I was going to make the plates not much longer than stock length and cut the centre out of the torsion tube to allow the engine and box
to go further forward shortening the bars, turning them down to get the right pressure.
I'll see when I do a dummy set up.
Why not forget about the torsions and the springplates all together?.... Just fit rose joint trailing links and coil shocks..... Much easier to tune the suspension then, and getting your toe angles bang on will be a snack!
do you think the kombi cv's will be enough for your horsepower
