Recieved my rebuilt frankfurt in the mail. negative seems to be bodied like everything else on the vw, positive running to ignition, and there the
only wires.
the 6/12v converter on the rear is correctly set to 12, and on the otherwide from he power wire is 3 speaker holes with an image showing 1 speaker o 2
holes and then 2 speakers to 1 diff hole and one the same.
can someone explain this to me.
ill try to get an image.
[ Edited on 5-4-2006 by 53racer ]
I have a similar radio, they are saying you can connect either one, or two speakers, -negative wire from each speaker goes to one plug, & postive wire
from each speaker must go to its own plug,
one thing that is stressed with the Blaupunkt radio is that you must NOT turn on radio under any circumstances without a speaker fitted
what connections do i use? a bullet 'spade' plug or a banana plug?
original special plugs---- dunno where you would get,
the Porsche guys jam the wire in with a matchstick-don't tell anybody!
are you serious :S
may crack open the rear and see if i can hardwire
yep, serious, poke the wire in & then a match or something to hold it in, thats how a few people have done it, I have no idea where you would get the original plugs to so;der on to the end of the wires - sorry
no worries, TY for the info.
just noticed you live like 5 mins away from me, hehe
just thought i'd add here, in just then cracking open the case i noted that the connections are merely a plug type connection and nothing greatly
special about them, bullet type 'spade' connectors or small series banana plugs can all fit snugly into these and provide a decent connection.
mono
I should add that the stereo radio did not come out until 1969
Blaupunkt was the first with this feature
[ Edited on 7-4-2006 by kombikim ]
only 5 mins from me? oh well, if ever you need help..............
ty. may see each other in passing
Just a thought. I wonder if you could get a fitting from Tandy or Dick smith?
On a similar subject, what sort of speaker can you use with these radios? and can you buy one new.
Rob....
Could also try these mobs.
Nostalgic Wireless Company
Pre 1970 car radios restored, vibrator type converted to transistor, 6 to 12 volt conversions,
Valve Radio repairs, restored radios for sale, AM to AM/FM conversions.
Contact:
629 Canterbury Road, Surrey Hills Vic 3127
Phone (03) 9899 8880
Fax (03) 9899 8887
Classic Radiomobile Co. (Sydney)...John
Ph: 02 9583 2056 Mob: 0411 821116
Rob...
TY for the info dude.
i bought mine in restored condition, so is cool. simply needed connections. i'm putting jaycar speakers in, mainly coz i work there i get them cheap.
simply any 4 ohms will do.
