I'm told there's a 'Auto Interiors' guy in Brisbane who can do this type of work. Anybody know of him?
We might be able to help. Give us a yell if you're stuck.
Are they not the same as a normal rear seat?
right. gotcha.
What year are you looking for? I can provide some measurements from a 1954 and 1961 car if you need them.
Hi Steve
It's a 1970 Standard. Not sure whether the 61 was the same set up or whether it changed in the interim - do you have a photo? The front edge (i.e.
the edge under the backseat passenger's knee!) of the seat base is approx 124cm. The problem is the depth (front to back) as the seat frame catches
on the cross member separating the battery compartment and foot well.
Adam
Stuart at Classic Car Interiors Windsor (Bris) or Nick at Outrage Interiors, Morayfield. Both should be able to help, be helpful if you had an old one for a sample.
I think the 61 measurements would only be good up to 67, 68-71 would be different. I'll get some measurements of my one for you though. From what I
remember I think the seat base is a wooden frame anyway, so fabrication should be easier.
Three changes. 58-64, 65-73, 74-79
OK - I'll try and take some photos and measurements over the weekend. Vic at VicsBahn is having a look through his stock as well.
