65 beetle headliner question
Mattriots - October 16th, 2011 at 02:40 PM
How does the headliner of a 65 beetle attach above the front windscreen?
The headliner goes behind a panel that the sunvisors are attached to
I wanna know if behind that panel if it is held by the windscreen seal or not? I'd don't wanna pull the windscreen out if I don't have to!
Cheers lads
1916baja - October 19th, 2011 at 09:25 PM
there will probably be a cardboard strip sewn onto the front of the headliner that hooks onto a lip inside that panel, so unless you can actually see the headliner going under the window rubber, no you don't need to take the windscreen out.
vw54 - October 20th, 2011 at 05:56 AM
it uses a cardboard trim to lock into the lip n hold in place thats if your making it stock
