If so, HELP!
I can't work out how (if at all) to make the thing fit. I have a double din from my old car that I kept, and would love to work it in to the beetle
if at all possible, but I don't want it in an awkward or silly spot. In the glove box is fine as long as it doesn't look like it was installed by a
monkey tripping on LSD, but I really would love to shoehorn it into the dash if possible.
Otherwise - can someone suggest a good single din headunit that allows me to run a touch screen to scroll through music folders and will read BIG
memory sticks/cards/hard drives? I don't want to scroll through a thousand music folders with a jogwheel/remote. And I don't just want to piggy back
in an mp3 player with an AUX cable or what have you.
I have looked at some single dins with fold up screens, but then they will block my dash air vents, so I'm starting to run out of ideas... short of
going completely MacGuyver on my dash with an Android tablet and fabricating equipment. And then I'd still need to install a CD player somewhere for
the CDs I haven't ripped to the computer yet... painful.
Thanks!
Have you given any thought to making a centre console,mounted over the transmission tunnel,incorperating the gearstick and intergrating it there?Saves chopping your dash up,and may even give you enough room to fit a couple of extra gauges if the need arises.You just need to be handy with plywood and vinyl..
I was going to suggest the same thing. I got this fibreglass one years ago to mount my CB radio. I don't have the CB any more, but I am planning on
fitting a GPS in there one day when I can afford it.
The advantage of the black fibreglass centre console is that it matches the dash and looks like it was a standard option.
There is physically not enough room behind the dash anyway because of the firewall shape.
I ran essentially what was a double DIN setup in mine in the late 90s.
A head unit and a DSP/graphic EQ mounted together in a custom console.
It's not too hard to make something up like mentioned.
I'm back to that now with just a single DIN headunit in my console
Lbugs run out of room quick when you start filling them with electrical goodies.
Ditch the double din, total waste of time and space, just not necessary. Sounds like you are making things more complicated for yourself than
needed.
We picked up a nice JVC head unit for under $100 from Super Cheap for under the rear seat of the beetle. It has an AUX output which i run a cable to
my iPhone and play my music through that. For a little more money you could get the same unit with USB and others there had Bluetooth function. With
todays technology you dont need big bulky units unless you want the "wank factor" of a pretty picture display.
Our other vehicle doesnt even have a head unit, merely a small amp and speaker installed under the bench seat of the Single Cab with the jack cable
pokiing up between the seats and we plug our phones in to listen to music and radio. That way we could have something "modern" without it being
seen.
Ash whats the radio reception like from the iphone? I've been thinking about doing the same for bud.
Absolutely awesome, but of course Iphone doesnt have an inbuilt radio as such and I use the TuneIn radio app so is dependant on phone coverage. Bob has an inbuilt radio on his HTC and that's fantastic.
I might measure things up, or maybe mount the head unit on a test bracket under the dash to see if it's too
annoying to use there/in the way of everything. So it's a good starting place, thanks! Did you have to relocate your fuse boxes or anything though?
I just swung my fuse box down and into the side of the fuse box. You can see it a bit in the photo, just below the fire extinguisher.
I will get a better photo tomorrow.
Ummm, you don't have wires hanging out the dash, it's a cable jack that plugs into the Aux imput on the head unit and removed. No one installs
double dins anymore, and the above was a suggestion as there isn't room in an L Bug for something so big and bulky and not pleasing to the eye. Ease
of navigation, ample storage and neat and tidy is not what springs to mind with a double din unit.
If you have so much music and want to listen to it on the go, why do you not have an iPod or other music storage device? It would make it so much
easier, plus eliminate the hassle inside your already small car. Plugging a music storage device such as ipod is far easier in terms of navigation and
eliminating clutter in your car. There is that much memory on an ipod, music storage has personally never been a problem! What I have mentioned is
what most people run these days with available technology for music storage, and will recommend on most ICE forums for small cars. Head units are no
longer for music storage, phones and iPods are.
I can see why you want to put in the double din setup - I find that trying to find things on my phone or whatever while driving a bit of a pain. If
the light isn't real good, I have to find my glasses and put them on. A big screen is sooo much easier in my opinion.
It also depends on what you are used to. I also can't see a lot of use in using up time to learn a new system when the way you already know works
very well for you - even if it does take a few tweaks to get it set up.
Anyway, here is my fuse box hanging loose while I had my interior out when I re-sprayed my car a few years ago.
And this is the fuse box mounted in the console. There is still holes from the CB that I used to have in the console, and you can see the second fuse
box that runs the alarm, remote central, electric windows, etc.
My plan is to fit a built in GPS into the console when I can afford it. I even have ideas of taking out the console, getting someone to make a plug of
it and filling the holes (making it a blank again) and making me a new one.
No time, no money though.
This is an early dash but the concept would be the same. This is a box made from MDF (craftwood). I just custom shaped it to the dash and mounted it with a couple of bolts, but you could build it full height down to the tunnel. I too used this unit out of one of my other cars.
You can get the type of cup holder that plugs in to the ash tray and that will allow you to use a centre console as well as leave you with somewhere
for your drinks.
Yogie
Sorry but I guess I just think the above looks absolutely awful, and in an L Bug even worse. My reference to no one installing double dins was nothing
to do with new cars, most new cars come with double dins already, I was talking about classic cars with small dash boards and limited space.
Best of luck with your mission
Isola, I guess with a centre console you don't need to cut up your dash, and when it comes time to upgrade your equipment or your taste it's not an
issue. What I suggest is to make a cardboard shape of your head unit and move it around the dash while your in the drivers seat and then plan from
there. But hey, it's your car and your personal choice .So if you want any advice on installation just PM me, Im not an expert but I can tell you
what I've learnt from experience.
Michael
Thanks for all the input, everybody!
I think that cardboard mock up idea is fantastic, Michael. I'll definitely test the waters with that! And thanks very much for the offer of
assistance.
I'm also going to keep my eyes peeled at cars that come through the workshop and see if there are any parts that already exist in other small cars
that I may be able to track down second hand and incorporate into my plans.
I would second going Ipod or similar with a single head unit.
In my wifes Corolla (yes not a vw, but) we just installed a new Sony head unit . It was about $130, and comes with USD out, extra input in the back
and Bluetooth. I would then add a cradle for the phone and your away.
With a iphone or ipod it connects straight away, and you can navigate either on the phone or on the head unit. No hassles with connection or similar.
Plus it gives you hands free phone when you want (main reason we wanted to install it). Plus if you never charge your phone, you have a USD plug to
charge in the car.
