These are scat solid rocker shim kits priced @ $ 82.49 ea . These kits are complete with heavy duty shafts and a complete shim kit that will turn your std type 1 rockers into a budget performance set of rockers without the risk of circlip falure . ROD, 02-42729920.
Hey rod did you get my e-mail?
Rod can you match these up with a set ratio rockers for a 1600tp I was thinking maybe 1.4 ratios
