I've received several queries from Australia inquiring about our products, primarily our pulley system. I charge $15 flat-fee shipping in the US,
but shipping to Australia added around $40. I checked my costs, sharpened my pencil, hemmed and hawed, wept, gnashed my teeth and decided to absorb
the extra shipping cost to Australia.
If interested, you can go to our website and order there for the posted US price ($233), with no penalty for being so far from the US. It would help
me out if interested parties could order together and save me some shipping costs, but single orders will be sent out promptly. We stock both
standard and sand pulley sets for the same price. Thanks for reading.
www.BullysPulleys.com
I've updated my profile per request. Currently reside in Charlotte, NC, but am moving back to San Diego as soon as home sells. My name is Ken
Janulewicz and I answer e-mails promptly at UptownDogCo@gmail.com if you have any questions. There are plenty of photos on my website. As soon as I
figure out how to post a photo here, I'll do it.
Hi, do you do supercharger pulleys as well? i have a sc14 with a funky clutched pulley (don't need clutch) that someone has put nails and weld
through :S.... and a replacement pulley here costs more than the supercharger
btw i love you vw stock. ![]()
Hi Chris,
On my website, there is a link to a video of our pulleys being used to turn a blower. The owner used a stock pulley system initially and several
other serpentine designs. All belts shredded on every run down the track till he switched to Bully's.
If you can adapt a standard gen/alt pulley to fit, ours will work. Different sized belts are available. The cost of making one-off pulleys for
specific uses is just too expensive to be practical. There are design costs, set-up costs, etc. that quickly get way out of hand. My pulleys are CNC
machined here from billet aluminum and custom pulleys are impractical, as mentioned.
Hi Ken, nice pulleys. And thanks for the offer to look after us Ozzies.
What ratio are they (stock, power or custom) as fan speed is very important in this hot land, and in the pic there is a tensioner, but it's not being
used, do you need a tensioner with your design?
Do you do any for other fan types, genuine Porsche or others?
They look good and I like how tough h/d the belts look
Hi Matt, the design engineers at Gates Rubber were sent a set of stock pulleys and designed Bully's Pulleys for me so that the ratio would be as
close as possible to stock. The remains of a serpentine system were just left on my car after I removed it awhile back. No tensioner is needed with
our pulleys. We played with several different numbers of teeth and slight diameter changes until the right combination was achieved. The belt rolls
on snugly and that should be it as far as tensioning or having to replace a belt. No one has ever had to replace a belt as far as I know, and I'm
sure I would have heard about it.
About a year ago, a metal hose connector came loose and wedged itself on the lower part of my crank pulley. By the time I pulled over, it had chewed
up one side of the belt and about 1/3 of the crank pulley teeth were worn down. I just left it that way for about a month until I got around to
replacing the belt and pulley. Both are very tough and reliable.
It's too complex and costly to offer one-off pulleys. They are CNC machined from billet aluminum here in the states and to redesign and reprogram
for one-offs is just not feasible. If you can get a stock VW pulley to fit, then we're good. One customer uses our pulleys to turn his blower on
his drag car (link on website of video), but he designed his system to use a stock pulley initially.
