VW Type 3 RHD Dashboard Skin $139.55 The dash is made of 3 mm UV-stable, leather finnish, ABS Installation instructions will be sent with each unit.
Will be bubble-and-cardboard wrapped. Please note the Dashboards are sold as seen on photos, what you see is what you get. So please look at the
photos, and satisfy your self if you want the dash. The dash has been made to the CAR size, so approx. 6 mm bigger then most SUN burnt dashes that
have shrunk in the car over years. This means, that you can fit it over your old dash, to give you bulk. (prevents it sounding hollow if tapped) OR...
You can fill the inside with foam spray, OR..... You can fit it as is. If fitting over old dash, you may have to trim old dash on a few spots to slide
it over. If filling with foam, place "cling wrap" over steel dash after removing old dash, spray a small amount of expansion foam into back of NEW
dash, and press into place, hold still for as long as can recommends. Do not bee concerned if foam flows out all over, let it dry, and break or cut
off, remove cling wrap, and fit dash. You may order your dash UNTRIMMED as per these photos, and you cut them out as you want. This is the best
option if you are a perfectionist. Alternatively you can get them trimmed by the factory that make them, please note that there may be some places
that you would want to file. Please use a steel file, not a carpet knife, as one slip, and the dash is damaged. Link to article that gives more
information: http://www.aircooledvwsa.co.za/viewtopic.php?f=72&t=20365 Package size: Untrimmed: 1430 mm(l) x350 mm(w) x 170 mm(h)
Trimmed: 1430 mm(l) x 170 mm(w) x 170 mm(h)
