Part Numbers
Iwish4aSynchro - June 19th, 2007 at 08:23 PM
Anyone know the part number for
Drive Flange Oil Seal on a T3 Caravelle/Transporter
I have been sent some via Mick Motors and although i have never done this job before thay look kinda small, too small to be what i need. The parts i have are about the size of a 50cent piece, bit bigger, also they are a solid meaning no hole in center for actual drive shaft exposure.
greedy53 - June 20th, 2007 at 07:36 PM
try vintage they repair them mate
http://www.vintageveedub.com.au/
[ Edited on 20-6-2007 by greedy53 ]
Menangler - June 20th, 2007 at 10:07 PM
There are 2 seals for the drive flanges, the inner one that fits into the gearbox, then the cv flange fits on, and then the outer one that fits into the cv flange (when it is in place) before you put on the cv joint, no hole in this one, sounds like the one you have.
Iwish4aSynchro - June 23rd, 2007 at 12:30 PM
I think i have it sorted now to get the job done. Might be wasting my time, as i am trying to ward of a rebuild. but 309thousand k's it's all getting a bit whiny and second gear is getting harder to select.
