well girjs and boys i'm having a bit of bother with the gear shift into 1st gear cold it's easy warm it starts to get a bit harder until you really
have to give it a savage push
is it a ajustment or a clutch job
The firewall on that model often fractured where the cable goes through, and old lawn mower blade is a good shape for a repair.
thanks steve that has been done a bit more info it dose not matter how much i tighten up the clutch adjustement it stays the same
i was wondering if the shift was in the correct alignment is there a ajustment part on these
The plastic bushes wear out a bit on those. Maybe you should talk to Matt @ Camden GTI, he knows all about this stuff.
now there is good idea thanks again
Yup - MAtt from Camden GTI would be my recomendation also.
Perhaps also have a
read of this
thank you will have a look at the bits mentioned
