My 1985 1900cc T3 drips fuel from the tank on every fill to the top. I've replaced the plastic pipe and rubbers but it still drips and has cost me
much money, especially at current petrol prices! The Brooklands manual is useless in this area (and many others too) so I wonder has anyone got a
picture of the tank system?
For example, what is the plastic tank for under the front offside wheel arch, mine is empty. but I can see a wet area further in on the fuel tank top
but it is hard to reach.
Any help appreciated as the mechanic has no further ideas.
upset.
Melbourne.
They are breather tanks
REALLY complicated set up
Guaranteed it will be something to do with those 2 stoopid plugs on the top and that cross pipe
I had the same problem on my 82 air cooled
Bugger to fix as you have to keep pulling the tank
Thanks Bizarre, that was quick! I'm still hoping to get a picture (copy) of the set up so I'll have to be patient.
Regards,
upset.
i will get you a pic in the next couple od days
Will scan from the manual
REAL busy at the moment
Yep, the two plugs/grommets in the top.
Can't help with a pic, sorry.
Thanks again Bizarre, really appreciate the help on this forum.
upset.
see if this helps
If you want the full size tell me and i will get your email address
Fantastic Bizarre, many thanks. Now I can root around and see where the leak comes from, I hope! Which manual did you find the drawing in?
upset.
this one - mine has a slightly different cover though
http://www.bentleypublishers.com/vw/vanagon/1980-1991/VW-Vanagon-80-91-Factor...
it sounds like a common problem as mine leaked a while back after i filled up with fuel and parked on a heavily cambered road....
might have to investigate this further hmmm
