Hi all,
Can anyone shed light on why i can login on this forum at work and be already signed in but at home i need to login every time and every 5min of
inactivity.
Both systems are very similar and the latest firefox on both.
I have deleted the cookies "aussieveedubbers.com" __UTMZ and __UTMA numerious times, recreated the shortcuts/quick links with and without the
"remember me" option ticked.
I'm looking at swapping the "cookies.sqlite" file to test if its in this database file or using the CookieSafe addon.
dont worry mine is reversed I am auto logged on at work and have to log on at home every time
its just quirk
Is your internet dropping out or are you shutting down the computer?
In Firefox go to Tools>Options>Privacy and select the link "remove individual cookies".
This displays the cookies that the site downloads to your system for login information.
Scroll down the list until you can see "aussieveedubbers.com" and click on the arrow to the left. this displays the actual cookie names. There
should be 3 - __utmb, __utmz and __utma. This allows the auto login next time you select the shortcut to the forum. My system at home only had 2,
__utmz and __utma.
So to get the 3rd one you have to go to the "Main page" (not the forum page) and use the login there. Once this is done you then get the 3 cookies
and your short cut to the forum will open the forum as a logged in user. Fixed.!!
A "quirk" is Dave speak for fix your cookies. See, he was right. ![]()
Thanks for finding a solution vman. Nobody had bothered to try and fix the issue before, which is unique to this website (for me).
