1 x 59 type1 floorpan very good cond. NO rust. $100.00.
1 x 58 type1 floorpan with no pans $40.00.
or $120.00 for both.
1 x L/bug rear irs chassis cut in front of shift rod inspection hole, Trailing arms, rear brakes, drums etc. good cond. $20.00. - PSMITAR.
1 x type1 1200 6V starter motor. needs cleanup. $10.00.
WTD.
1 X Oval rear window glass.
1 X R/H tailight housing only. pre 59 anything considered.
Mike 0488448470.
Woori Yallock. Vic. 3139.
Melb outer eastern suburbs.
Can I take the four tip exuast?
Mike
Done. r u local 69bug.
Yes just in Ringwood!
Pick up sometime during the week ok?
if i 'm coming down ur way in the next couple of days i give u a yell if u wanna sms a no. regards mike.
I might have yr tail light, just need to check the side... im in east doncaster, sonear to Ringwood.
Hi 69bug, Will give u a call in the morning and organise a time to drop exhaust off. just got back into town.
Empi , i'd appreciate that, let me know i'll be in around ringy in the next two days.
regards Mike.
Good stuff
A few other bits i found in my garage tidyup.
Pm sent
Empi - you have email.
I would love that Half IRS floorpan but I'm al the way up in Brissy. Any idea of a courier or transit service that would get that up here?
Cheers,
Mike
Good question, what suburb in brissy. If i can work out a weight on it i'll ask at work (Aus-post)
. I'll get back to u on that one. regards Mike.
Is it possible to pinch the cover which goes over the top of the accelerator linkage where it connects to the cable? (Mounts in passanger
footwell).
Cheers,
Tim
psimitar, i'll check it out on monday at work & message u when i get home in the arvo.
Tim i'll check and see if i've got one & get back to u.
Regards Mike.
Hi pmsitar the cost on post is ridiculas although a thought is that if anyone is going to sydney for the VW DRAGS meeting they might be able to give
it to one of the queenslanders going home to take back for you to brisy, maybe a post on the subject would help. i'm happy to drop it off within a
reasonable distance if it helps.
Sorry about the time laps to get back to you man.
Tim. Nogo on that cover on any of the chassis i've got buddy. Sorry it took awhille to get back to you.
Email!! diddnt get one.. do u still have the floor pans? any idea what the cars were that they came from (details etc)
Hi EMPI, i actually sent it to EMPIKG by mistake who if i remember correctly is now GASBRNR. The pans are 58 & 59 going by the samba chassis
listings. Hope that helps.
Cool, seeing as the Sydney Dragmeet has been rescheduled it might be the right time to organise something. Regards Mike.
Mike did you find a tail light housing, got one here for you.
OL
Thanks man, i haven't forgot about it just been a bit sidetracked by one of my partners two wheeled toys (r/r trackbike) i''ll give u a call this
week & organise a time. thanks.
