I have 2 sets of flat style tail lighs
One is the square style and the other is the domed
Just selling as one kit
the lenses fit the same base
The square lense is the better lense. It has some prismatic properties and havent realy faded much.
The bases for those were just black. I painted them inside hammertone silver to get a bit better reflection
The domed lenses has no prismatic property at all and is next to useless on the road.
But the base is really good (next to new).
It came with silver inside
The domed lenses have faded quickly and when I bought them there were some cracks and breakages - bought them on line. Shop said they would change but
were busy at the time. All too hard so I just kept them
But if you want flat - put the squares on the other bases and you wil have a great set up
The new bulb holder works bloody well and I will supply the others as well. They are not as good and a little bit of fiddling is required to get the
bulbs to work
So - 2 sets of lenses, 1 set of bases (unless you also want the other ones, and 2 sets of bulb holds
$50.00 + $10 postage
Barry
0499 658 561
Abbotsford NSW
Also have a set of rear (?) non retractable seat belts for free (well $15.00 postage if required)
Not sure what they are suppose to be off but they were in the rear of my L bug and they are small.
Might fit children - but I have bought new front and rear
They are VW / Repa
Could be ok if the shoulder point was lower ??
They look to be the originals?? So almost 40 years
I wouldnt call them freyed
Whatever - before I throw them out - someone might want them??
what colour Baz?
I think ill take them
