i have for sale a complete under the decklid draw through turbo setup. was running on my daily bug driver on a 1916 engine. At a modest 7lbs boost was
generating 120hp at the wheels.
System uses a 40 DCOE through a T28 (i think) turbo. All in good condition. Turbo has carbon seals.
I will be including a spare 40DCOE in the price offered. this carb is in working condition however idle screw has broken off in the housing.
will include all connecting exhaust pipes, delivery pipes and siliconn hoses to inlet manifolds.
Header not included.
i am looking for $1500 for the lot.
Call Ben on 0478 474637. system is located in mount isa, queensland.
Any vids of this running?
sorry. i have sold engine. all i have is a dyno sheet.
What modifications to the header would be needed?
i am fairly sure it is a standard 3 bolt header used for common performance exhaust systems.
So is this a ready to run bolt on kit? Anythijg need to be replaced?
nothing needs to be replaced. depending on engine size you may need to play with jetting etc.
header picture attached
header picture
Hi, just wondering if this is still available?
sold bud
