WTB: Ej22 or Ej20 crank and rods
Crais - March 14th, 2013 at 05:53 AM
I see a few on here have had multiple ej series engines, surely someone has these going unused in a spare block somewhere?
Would need postage to Townsville 4817
Regards
Craig
Joel - March 14th, 2013 at 08:33 AM
They are so cheap and easy to get not many people keep old engines.
If you don't mind the postage costs Ill swing by the subi joint here and see what they want for some.
Both my EJ22s went in the bin, bummer as the bottom ends were perfect on them.
One just had case rot and the other had no heads or water pump.
MickH - March 14th, 2013 at 08:35 AM
You have been sent a PM with my number Craig.
reub - March 14th, 2013 at 09:57 AM
I've an ej20G crank, rods and pistons up for grabs, but in perth... postage could be exy.
Calcool - March 14th, 2013 at 12:17 PM
Depending on what heads you have go and see Key Motors your local Subaru Dealer for a Short motor. Brand new you might be surprised how cheap a 2.0 or 2.5 turbo short motor is.
Cheers,
David
Joel - March 14th, 2013 at 03:49 PM
You've got PM
bigrudi - March 15th, 2013 at 07:25 PM
got some bits in sydney
bugzla - March 15th, 2013 at 08:39 PM
key motors is brisbane price x2
Klaus - March 15th, 2013 at 09:38 PM
have a complete ej20t inc comp, water to air intercooler from a 93 legacy $1000
bugzla - March 15th, 2013 at 10:21 PM
klaus whats the freight to townsville 4814
Klaus - March 16th, 2013 at 06:53 AM
fk knows last subi motor i strapped to a pallet and sent to brisbane area cost $290.00 , there is an e-go depot down here which may be cheaper , in wollongong montague st .
bugzla - March 16th, 2013 at 07:19 AM
yeah tried to send a short block to aulbury $557 what a croc hey
Klaus - March 16th, 2013 at 09:36 AM
if you know anyone whos going to the nats at the end of may , i can bring it to there then get taken to bris by someone then sent from there
Crais - March 19th, 2013 at 06:32 PM
Thanks to those who replied and Pm'd. I was unable to reply due to low post count but have now sourced a long motor from MickH
