NEW DRAG TRANS.
RodPenrose - April 19th, 2013 at 07:33 PM
I have cleaned up the shed and have found another new transmission that is suitable for drag racing only . I purchased this years ago from Ron Townsend and this was his spare pro turbo tranny . This has been completly freshened and has the following components;
Late vw mag case with welded gusset
3.88 ring and pinion
3.55 , 2.06 , 1.56 and 1.12 gear stack
1st gear has no syncro ring ( Must have in gear before starting )
2nd gear has a liberty pro ring
3rd and 4th has new syncro rings
Dual HD aluminium side covers fitted with timken tapered rollers
Aluminium spool
Late throw out bearing
Late clutch arm
This trans. is located in Wollongong NSW and is priced @ $ 2800 , ROD , 02-42729920 .
whathaveidone - May 3rd, 2013 at 08:07 PM
Bump.
