FS: KYB Mono tube shocks (not twin tube) SOLD
GTMac - May 5th, 2013 at 03:26 PM
KYB Mono tube shocks (silver). Part # KG4521
Will suit all Type 3, early king pin beetles, rear swing axle beetles, Karmann Ghias, Bay window fronts I'm sure as well.
Used on my Fasty for 5000km and then been in shed for last 4 years.
$50 pair
Can text pic to anyone that requires but I'm sure you know what they look like.
Cheers, Andrew
Parts in Rockdale
PM me or text/call on 0410691015
psimitar - May 5th, 2013 at 09:18 PM
so these have the rubber mounting eyelets top and bottom of the shox? Being silver are they the GR2 version?
Thanks,
Mike
vwo60 - May 6th, 2013 at 07:37 AM
KG4521 is a gasajust number, i have them on all my cars, a good shock. front link pin.
psimitar - May 6th, 2013 at 09:13 PM
Originally
posted by vwo60
Hmmm, interesting
do I have the spare spondulees
GTMac - May 7th, 2013 at 12:51 PM
Originally
posted by psimitar
Thanks,
Mike
Yes rubber eye mounts top and bottom but I honestly don't know what GR2 is.
psimitar - May 7th, 2013 at 10:34 PM
Originally
posted by GTMac
posted by psimitar
Thanks,
Mike
No worries dude, VW060 answered what version of KYB they are. The Gas-adjusts are still good shocks just not as stiff as the KYB GR2 version.
vwo60 - May 8th, 2013 at 10:19 AM
The gasajusts are there top shock for beetles, they are a high pressure shock were as the gr2 is a low pressure shock, they are stiffer that a gr2 but
i find them a lot better in the handling stakes, i find the gr2 under damped and not suited to my set up.
psimitar - May 8th, 2013 at 10:38 PM
Originally
posted by vwo60
oh, When I read the KYB bumpff the GR2 sounded the stiffer. Cheers for teh correction
psimitar - May 10th, 2013 at 07:17 PM
Cool. Looks like I'll have em dude if ya can just wrap em in cardboard and measure n weigh em for me.
I estimated the weight at 5kg and length at 40cm, 15cm and 10cm. Got a quote of $14 door to door
If I know the exact weight and dimensions then I'll know the total cost but shouldn't be much more.
Ta,
Mike
