Wtd Splitty disc brakes
panelman - June 10th, 2013 at 02:40 PM
Im after a set of discs etc for a 62 split bus with K/L beam, new or used.
Im runnin bay pattern brms.
Cheers Shaun
TheMiniMan - June 12th, 2013 at 06:59 PM
if you got a 68 model balljoint beam assy , then you can fit the later disc assys onto that & then it all pretty-well just bolts straight into your splitty
just in case you didn`t know & maybe gives you another option is all
nils - June 12th, 2013 at 07:05 PM
Running discs from sherman conversions on my front end, in the bay kombi stud pattern, I'm happy with them
panelman - June 13th, 2013 at 06:47 PM
Thanks guys decided to go with the Sherman discs.
