Needed:
Ignition for a beetle.
Prefer a set with door barrels
Also need a Front bumper for a 70's Super
What ya got?
You'll need to be a bit more specific than that, there is the ignition switch and the key barrel, I take it you need the key barrel?
Also what year? there is 3 different key barrels and 4 different ignition switches used in 70s bugs.
where are you, I have 2 front bumpers, but I'm in Sydney so freight would kill if your not around here
Thanks guys.
I will take a photo and post.
I'm i Bris so Sydney is out (Thanks 1303Steve)
I have a few key barrels lying around and am pretty skilled with rekeying. If I have the right one I can match it to your door barrels. Otherwise if you find the correct type and want it matched i can probably help. Cheaper than a locksmith. I'm in Brisbane too.
