Hi all,
I have a number of surplus items available after various builds lately.
All parts located in Launceston, Tas., will post at buyer's expense on most items. PM me with a postcode for a price.
Cheers, Steve.
PM or 0407 090 904
Kadron kit (Dual 40mm), 5,000kms old, in good condition. Comes with complete linkage kit (stock), freshly recharged K&N air filters, chrome tops,
manifolds. Can supply new intake gaskets and fuel line at no extra cost if required. SOLD
CSP bellcrank linkage kit for Kadrons. Complete premium linkage. Barely used (less than 100kms) SOLD
EMPI valve cover vents $10
CSP Stainless steel heater hoses cut for doghouse cooler. Minimal use. $30
Stock 1600 pulley (New and unused Brazilian) $20. New fan belt to suit $10. (Or $25 for both)
AS41 case, freshly align bored and bored for 90.5mm, crack tested. Comes with head studs and main bearing set to suit .25 OS crank. SOLD
Used 90.5mm piston and barrel set complete with rings and gudgeon pins. SOLD
EMPI header and muffler 1 3/8". Surface rust only. SOLD
Hi Steve, just sent you a text re the carbs.
Hi Steve,
Interested in the case and Piston Barrel kit, will pick up.
ben
0413333833
PM sent
All PMs replied.
Case and piston/barrel set sold.
Cheers, Steve.
Bump
Ill grab the csp linkage for the kads if you still have it mate..
How much to post to Barden Ridge 2234?
PM's replied. CSP linkage sold.
What size motor were the Kadrons used on?
Kadrons now officially sold and sent.
Hi mate, received the linkage today. Thanks a lot!
Hi mate, glad to hear it. It's a really nice set up, enjoy!
