hey
im after an exhaust system that has heat risers to fit 62 beetle, 1300 cc
That's good, but where are you to know if we can help!
Kev
im in cambewarra, nsw which is near nowra in shoalhaven area
thanks
do you want a standard system or extractors ?
im after extractors, with heat risers
I have these if you're interested.............they give the best ground clearance of any extractor.
Pm if you're interested.
am thinking heat risers as he wants - are the two metal cups which catch heat from J tubes to go into the heater bx ??
anyone ?
na im talking about the outlets on some extractors that connect onto the heat risers on the intake manifold that preheat the inlet gases eliminating icing. some aftermarket extractors dont have them, but i want ones that do
There's one on eBay for $50. Not sure what its like though.
So you don't want the ones i have ?
hey craig, i sent you a pm a while ago, well aleast i thought i did, i really like the look of your ones, i cant make out if it has heat riser outlets tho, which is important for me, will it fit into standard heater boxes and what mufflers would fit that flange? cheers
Howdy, yep it has heat risers and yes it will fit heater boxes. I think I have a spare flange that you could have welded to a muffler...............may even have a muffler floating around. Try the pm again !!
craig,
pm sent, i think, (i cant find a sent folder on my messages page), happy to take what got, sounds perfect. thanks
myles
No Pm at my end !
