(Wanted) T3 Carburetor Linkages
58camper - August 14th, 2013 at 07:50 AM
Looking for complete linkages to modify for use on Country Buggies.
Female end connectors to accept 6mm ball studs are the key
Located in Nowra NSW
PM or email me.
countrybuggybill
vwo60 - August 14th, 2013 at 09:25 AM
I gave up trying to find the ball joints for mine, instead i used these with 5mm threaded rod, these will work on the standard ball but the balls that come with the joint are slightly larger, will not drop of the ball joint when worn which is a common problem with the type 3 linkage, try scott70wagon for the rest.
http://www.ebay.com.au/itm/160684837558?ssPageName=STRK:MEWNX:IT&_trksid=...
That gives you ten ball joints.
