WTB - Judson Supercharger 36- 40 hp any condition.
Located in Melbourne
Interstate is absolutely fine.
info@mioche.com.au
Hi there, i've got a 40hp one that has been reco'd and has all new bearings and seals.
Has been NDT inspected with no cracks found.
Faces machined within tolerances.
Original carby and judson aircleaner.
New oiler.
Only thing I don't have is lower pulley but I was going to use serpentine belt to run.
Only needs to be assymbled. I haven't rebuilt because I didn't want to put it together and just sit there.
I'll rebuild when I want to use ensuring everything is fresh.
Might be interested to part with for right money.
PM me with what you are looking at paying for one.
Cheers, Gus
a bit of advice the 36 and 40hp housings are different in mounting studs locating and that makes them sit different on the manifold
so they vary, plus the 36s have twin drive pulleys and the 40s have single with and idler wheel
I have one of each fitted to both 36 and 40hp engines
I didn't think the idler was a original part but a re engineered piece that could be fitted to either 36 or 40 hp engines?
Also interested in any parts associated with the Judson supercharger.
Pulleys, linkages, etc.
I did get onto one a while ago but the guy couldn't make up his mind if he wanted to sell on not BUGGAR
http://www.youtube.com/watch?v=jCoePBAQFvU
40hp for sale
http://www.youtube.com/watch?v=-LX7vfvSiuo
Looks like a good buy...
Any Judson's, still looking if you are thinking of parting with one.
Hi Eddy, tried to call but no answer.
Can't pm either as haven't posted enough to be allowed yet.
Working on that.
Pm me your email and I'll send photo's if you like.
Would take approx $1800.
All new bearings, seals and vanes.
Carby, linkages, original judson air cleaner and brand new oiler.
Only thing needed is lower pulley.
If it doesn't sell then I'll keep it for the Oval.
Cheers, Gus
Hi Gus,
PM sent.
