WANTED 1957 Split Case Transmission
6volt - November 26th, 2013 at 09:30 PM
I know this is a long shot but I'm after 1957 Split Case Transmission.
Needs to be stamped between -
A-1114506 and A-1189006
Craig Torrens - November 26th, 2013 at 10:01 PM
where are you located ?
matberry - November 26th, 2013 at 10:15 PM
I have a few, you want complete, working, case, parts???
Can you be more specific
6volt - November 26th, 2013 at 10:25 PM
I'm located in Victoria.
I'm happy to organise a courier for pick up.
Most important to me is the case with the correct numbers.
If you have anything pm me with the details.
Thanks!
bnicho - November 28th, 2013 at 09:56 PM
There is a split case trans lying loose inside a crumpled Oval at Flynn's Wreckers in Cooma NSW. I don't know what numbers are on it though, and he is not cheap!
6volt - December 2nd, 2013 at 07:58 PM
i'll keep that in mind. thanks
matberry - December 3rd, 2013 at 08:32 AM
I have 5 or so, just no time yet to check numbers as they are not easy to get to. I will do it for you some time if you wish, but may take time.
