Ok not to keen to do this but shit happens.
Item: I have for sale a 1968 ball joint, swing axle rear rolling pan for sale.
Condition: Reconditioned. Left and right pan halfs replaced (properly - that is old pan haves un-picked and new halves spot welded on) lower front
bulk head replaced. The old one had some rust holes in the grooves and i didn't want to bodgey it.
Front end recoditioned - new needle bearings and seals, selecta drop installed for raising front (un-adjusted sits at normal height), new monroe
shockies.
Gearbox degreased and new rubber boots installed. have seals to do outer wheel bearings but haven't got to it (the old ones dont leak anyway) New
brake cylinder and all new brake lines and hoses. It has a cutting brake installed as well. This seperates the left and right rear brake lines and
allows independent application of the rear brakes via a handle to increase turning and or traction.
A few other bits and peices as well like pedals/cables etc.
This was to be the base of my baja but circumstances have changed.
Contact: Sam 0407426059 or txt/pm (can't always answer phone during office hours)
Price: $700 neg
Photos: Will get some of the underside as it has a body sitting on it full of the project pieces.
F.S 1800 beetle motor, Warwick, qld
Item: 1800cc beetle motor in good condition. Was running very well but has excessive end play so was removed for rebuild before it got damaged.
It is a single port with a Holey Buy spray, it was going into a baja so doesn't have all tinwear just the fan dog house. have a 1500 single port
complete which has everything stock on it (seized) you can take with it.
Still runs fine but will need bearings.
Price: Offers
Contact: Sam 0407426059, txt or pm also fine.
Photos to come.
The Holley bugspray carby and manifold are not pictured but it is good.
Also for sale
black vinyl seats front and back with blue cloth inserts. Front not original VW beetle but are tilting and welded to VW rails.
Offers
Also have a full carpet set in black in good condition.
Engines sold.
