Im after the main bracket that holds the rear hatch on, plus the little bracket directly attached to this:
Passenger side required
How do you even get them out? What's wrong with yours?
ask Alec 'kombisaint' on here
he's the guy I think would have em
he is in toowoomba
about 3 or 4 bays up for grabs at VVDS
http://forums.aussieveedubbers.com/viewtopic.php?tid=104802
I'll give instructions to remove it or come and grab it myself, im in sydney though.
There is 2 pins, with a circlip on each then remove the pins and the main bracket will come out, on the smaller piece there is a pressed pin which
will have to be drilled or removed with an oxy or something.
I have been told that lowlight is different brackets to bay however i cant confirm this.
No luck, still need this.
I also need the missing parts for the right side of this pic
