Must be in good working condition. I am after the smaller diameter one to suit a 36HP motor.
PM me if you have one you can part with.
I am located in Melbourne.
Cam
Late 356, and early 912 Porsches had SMALL diameter, 12v generators. Make sure it is the SMALL diameter one, as the later 912 were BIG diameter.
http://www.ebay.com/itm/VW-Generator-12Volts-GR11X-Replacement-for-the-6Volt-...
Not cheap but hey not many around either.
Industrial motors are a good source for these, the two I sold a while back came from air compressors. I have a third but I had to get the armature out with a press and was rusted beyond reasonable repair.
I think the industrial 12v generators are fairly low output - not much good for high wattage lights, etc.
No, they are 38 amps.
Some of the small dia. 12v Porsche industrial generators are 11 amps.....just a warning.
So do the industrial ones have a different part number?
Bosch 0 101 206 116
VW 113 903 031
IND BRASILEIRA
14V 38A
I got one here for you.
