Surplus Drag Racing Parts
HS618 - February 17th, 2014 at 10:13 PM
Hi All Drag Racers,
I will be taking some no longer needed Drag Racing related parts to the Drags in Sydney this Saturday. See me on the day if you are interested - after about 35 years of Drag Racing, you accumulate lots of stuff!!
(Moderators and Craig, I hope this post is OK with you - if not,please PM me)
Parts are:
4 x Bridgestone Formula Vee fronts (22.5 x 15) suitable for front runners
2 x beetle front discs at minimum thickness, Porsche stud pattern with studs and nuts
1 x White rhino gearbox case (near new)
1 x magnesium rhino gearbox case (used)
My highly modified Street Eliminator heads 46 x 40 titanium valves, including modified 48 IDA inlet manifolds and gaskets (flow figures available on request)
1 x new 6 bolt flanged flywheel and J&G style pressure plate to suit 1/4" engine plate
4 x new 5.5" H beam conrods with 5/16"ARP 2000 rod bolts
2 sets of 94mm barrels (various piston clearances)
1 x new 45mm Dellorto DHLA side draft carburettor
No pictures, see them on the day
Lots more parts to come after the VW event
jamiesc - February 18th, 2014 at 07:57 AM
how much are you chasing for your heads?
cheers jamie
