Hi guys,
I have reconditioned 40hp motor thats had the complete once over. things done
- new big bore pistons and barrels 1390 odd !!
- new crank and rod bearings
- new conrod bushes
- case machined for cam bearings
- case machined for full flow oil filter
- heads blasted and valves lapped, good guides etc
- reconditioned 010 distributer
- new period correct fuel pump
- 1600 1.1 ratio rockers
- good flywheel
- new platinum spark plugs
- new leads
contact me for more info.
Has a complete tin set which was sand blasted and primed, not top coated as yet. 36 hp type fan housing.
Never run as im going back to a 36hp period correct engine. Can assist with twin carbs too if interested for extra $.
Paul
0439 800 880
Cost $ 750.00 ono
Pm sent
Dan
Steal
