Case is AS21, bored out to accept 94mm pistons
Mahle 94mm pistons and new longer barrels CB Performance 0.060 Copper Head gaskets
86mm Cranks, main bearings .020" Mahle
New 5.6" Cb performance H Beam conrods 2" Chevy Journal
New 125mm cam new engle Scat Lifters
Schadek 30 HD Super oil pump with Gene Berg full flow
Alloy push rod tubes
CB Performance 044 Super Mag Round Port Heads 42 x 37mm S/SValves, CNC Porting, Dual Rev Springs,Chromoly Retainers, And harden Valve Locks Scat
rockers
Deep sump
New Total seal rings
Kennedy stage II Pressure plate with new clutch plate
$4250
Chris
0419 621 540
Stanwell Tops NSW 2508
Hi, what brand is the crank and who assembled it?
this would be fun in my bus!
Dan
