About to start parting out a 70s lowlight camper. Body has had a lot of cuts taken from it before I got it and has rust aplenty (before the purists start complaining about wrecking a lowie) but still a lot of good bits. Front beam, rear IRS, stock rims, 1600 gearbox, fuel tank, poptop, front bar, fabricated rear bar with towbar, front and sliding doors, rear door, engine lid, some dash parts, low back front seats. Parts available in Morayfield Brisbane from a few dollars upwards. Can courier stuff if needed and post smaller stuff. Contact Paul by PM.
Can you send pics of sliding windows? Ben 0401 839 946
PM'd Seats
Has flipper windows not sliders Ben.
Will know on the weekend when I get a chance to have a look at the car.
G'day, would you have the inner support panel behind the orange hinge panel? If so, how much would you like for it?
This panel.
I'lll take second dibs on the flippers...
I need just the glass...
Baywindowbandit if it's the same as yours (has big lights is a late 72 model) then it's there just not sure of condition. Area above engine is
pretty good so should be ok. Will check on the weekend. For cuts if you come and do it yourself with your own tools I usually say just pay what you
feel is fair. If I have to cut it depends on time taken and consumables used.
Adlbeetle66 will let you know about the flippers.
Fronts would be going into mine bern if this had them. Rears only in this one.
What's the rear bumper and tow bar look like?
David
041902232 eight
Will get some pics and go through stuff for people during the course of the Easter weekend plus I have Thursday off.
Rear bar has been made out of square channel, looks pretty solid and could probably be fitted on later square bumper bay brackets too.
Bump. Sliding door excellent condition with only a tiny bit of rust under flipper window, engine lid excellent no rust, have tailgate, rust free but it's dented, Sopru camper fittings like old fluro light, poptop tie down latches, pop top metal hatch and internal fly screen, loads of stuff. Poptop is cracked on one corner and canvas is gone but base part is ok, no mech in it but if someone wants a good base and wants to pull it off it's free (otherwise it will go to scrap with the shell).
Would you have the factory water tank by chance .Thanks Carl
Sorry Carl. Most of the camper fit out was already gone when I got it. Although with the poptop cracked and the top hatch cover off it the inside is kind of like a water tank with the rain we've been having.
Do you still have the front doors?
If so what condition are they in?
Front doors are gone sorry. They were rusted.
PM,d regarding front bumper
Parts still here include sliding door (almost rust free), tailgate and glass, a few side windows, 1600tp, a few good cuts that can be taken from the
shell and plenty of good German steel left on her, rear bar/towbar (heavy duty fabricated bar) and lots of little odds and ends. Body will be cut up
over the next week or so. In other words don't wait if you need something.
If anyone wants to come and remove the damaged poptop it's yours for free or it goes to the dump.
Hey mate, do you have the brake reservoir from under the dash?
Got a good condition wiring harness for on the top of the alternator?? I believe mine was from a 74 Kombi...
Taa
