Hey veedubbers,
I'm doing a bit of a tidy up and there are some things I won't be using any time soon so I thought I would put them up for sale. If your
interested, shoot me a pm - I can then give you my number and we can discuss more if required, I can send photos if you need them.
- nos Mahle 90.5mm (a) piston and barrel set. Brand new. Still has the cosmoline covering. Imported from the states. Make a 1776 or bigger with a
stroked crank. $380. SOLD
- nos Mahle 92mm (a) piston and barrel set. Brand new, still with the cosmoline. Though one has some surface rust on the barrel from not being stored
as well as I had thought (grrrr). These are thinwall. So not recommended for a bus. $300.
Edit - I have had a closer look, two of these have been trial fitted but not run, there is evidence of a gasket product near the sealing surface. The
price has been knocked down due to this. I can bring them to the nationals if your interested. I will be there early.
- used Mahle 90.5mm (a) piston and barrel set. Good for a learning engine builder or someone with a tight budget. Will need a hone and new rings.
$100. Good to go, engine failed for other reasons (nothing to do with pistons and barrels).
Located in western Sydney. Fairfield area.
Phil
sweet, ill take the new Mahle..
Not sure what you mean Warb?
Bump!
NOS MAHLE 90.5 - pending payment.
Can arrange collection at Nationals.
Update
90.5 sold.
New Mahle 92s still available - see additional comments in original post.
Used 90.5 still available.
I also have stock 1600 twin port heads with rockers. Looking for $100.
Had a couple of questions re: the used or the new Mahle's. Could you send me a text so I can call you.
0414 275 995
Text sent norbert, give me a call tomorrow.
Also got:
- twin port heads - cut for 90.5/92s. Good used condition. No cracks. Can include stock rocker set up too if required. Looking for $250.
- weber carbs and linkage, air cleaners and twin port manifolds. 36 IDF dbbl carbs. Awesome bolt on for a 1600 + motor. Looking for $600.
Phil
