Time to make space and get some funds together for my project
I can send larger photos if required.
Please ring me on 0408 382 781 to discuss any questions you may have. I may be able to arrange freight for interstate buyers at their expense.
36 HP BEETLE LONG BLOCK CONDITION UNKNOWN
AS YOU SEE IT, IT DOES NOT ROTATE FULLY; IT GOES PART WAY ROUND ONLY.
$250.00
EARLY BEETLE SPLIT CASE GEARBOX NEAR COMPLETE
COMES WITH ANOTHER EARLY BEETLE SPLIT CASE GEARBOX PARTS AND ½ OF CASE.
$150.00
BEETLE FIBREGLASS REAR GUARDS
STOCK SHAPE WITH LIP FLARE AND SUPERBUG TAIL LIGHTS.
TWO SETS OF TAILLIGHTS INCLUDED.
$150.00
LINK PIN DISC BRAKE CONVERSION KIT USING MAZDA RX2/CAPELLA HUBS AND DISCS
INCLUDES 5 X PECO STAR MAZDA (4 X 110PCD) BOLT PATTERN WHEELS.
READ DRUMS DRILLED TO MATCH
BOLTS ONTO STANDARD LINK PINS - NO MACHINING REQ.
$250.00
REAR DISC KIT BOLT ON 5 STUD.
USES MODIFIED KOMBI DRUMS, RENAULT 10 DISC AND CALIPER WHICH HAS HANDRAKE MECHANISM
1 DRUM HAS STRIPPED SPLINE, SPARE DRUM FOR MACHINING SUPPLIED.
$180.00
MK 1 GOLF OVER RIDERS FOR STEEL BUMPER.
FULL SET FOR FRONT AND REAR OF EARLY STEEL BUMPER MK1 GOLF.
$150.00
MK 1 GOLF REAR HATCH PARCEL SHELF SIDE SUPPORT PANELS
GOOD CONDITION, NO SPEAKER HOLES CUT IN THEM, ONLY ONE TAB ON EACH BROKEN/DAMAGED. NAVY BLUE FABRIC COLOUR.
$50.00
MK 1 GOLF RADIATOR
REASONABLE CONDITION WAS USED BRIEFLY IN A NON VW RACE CAR FOR TESTING.
$75.00
VW CD MP 3 STEREO UNIT
IDEAL FOR UPDATING YOUR SYSTEM OR REPLACING ONE WITH WORN/ILLEGIBLE BUTTONS TO FRESHEN UP THE DASH PIN CODE PROVIDED
$120.00
Bump - refresh photo
